IPCC-E and Outbound Dialer Mode PREDICTIVE_ONLY
May 16th, 2009
I have IPCC Enterprise with outbound auto dialer with PREDICTIVE_ONLY mode to provide some IVR announcement to customer.
I am facing some problem with the auto dialer. When the call is connected to the customer it does not play automatic IVR music. Customer has to say hello or something to hear the music. If the customer does not say any thing in between 5 second then the calls are dropping.
Now I need to know how I can remove the voice detection option? Or how I can configure like, it will wait for 7 second to play IVR prompt, In between 7 second if the customer say hello...then it will play the prompt, If the customer does not say anything then it will start play prompt after 7 second.
arifsultanal Thu, 05/21/2009 - 19:12
Our dial peer is a POTS dial peer. no vad is not enable there.
Yeah I have seen that cisco recommends that vad should be tuned off. I could do test on my system and revert back to you.
arifsultanal Thu, 05/28/2009 - 02:38
bellow is my Dial peer configuration.
dial-peer voice xxx pots
tone ringback alert-no-PI
description ********
destination-pattern 16T
progress_ind progress enable 8
no digit-strip
direct-inward-dial
port 3/4:D
forward-digits all
prefix XXX
no register e164
What I can see at your given link and documet is lots of registry setting .
Can you tell me a littlebit about IVR outbound call registry setting.
Best regards,
Sultan Al Arif
villarrealed Thu, 05/21/2009 - 09:41
  • Bronze, 100 points or more
Try unchecking the IP AMD checkbox in the campaign configuration.
arifsultanal Thu, 05/21/2009 - 19:06
hi
I have checked with unchecking the IP AMD checkbox in the campaign configuration. But result was the same.
Is there any issue with the dialer?
arifsultanal Sun, 06/07/2009 - 19:52
Thanks to all who have given there valuable time here. I have done this by unchecking CPA (Call Progress Analysis) at Campaign Manager.
Sultan Al Arif
