Change the boot var
May 16th, 2009
  • Gold, 750 points or more
I am facing a issue with a MSFC card.
When i enter the boot statement as below
boot system flash bootflash:<image name> and when i see the output using show boot it displays the image name which i specified in the above statement appended to the existing image.
And when i remove the boot statements for which the other files are specified it doesnt modifies the bootvar.
Kindly advice how can i change the bootvar.
Mahmood
JamesLuther Sun, 05/17/2009 - 09:01
  • Silver, 250 points or more
Have you saved the running config? The bootvar isn't updated until you "copy run start"
jimmysands73_2 Sun, 05/17/2009 - 10:16
Can you post the output of your commands?
