How to check DSP modules installed status
Shibu1978
Dear All,
How will I check up the DSP modules installed status in cisco 7206 router.
How can i know whether those DSP modules are installed with
2 Channelized E1/PRI port(s) or in the chasis itself.
Shibu
12 Replies 12
Adrian Saavedra
Level 7
Level 7
Hi Shibu,
You can try with show diag and show voice dsp commands.
Hope this helps you, if it does please rate.
Best regards,
- Adrián.
Dear Adrian,
Thanks for the quick reply. please find attached the output of those 2 command . can you tell me where the DSP modules are installed ?
The 7200 chassis does not support direct installation of DSP modules.
Consequently, these are installed in the PA, as the output of the commands is telling you.
Dear,
Thanks for the reply.
Is it PA - Chanalized E1 port.
Shibu
'show voice dsp' should show you the DSPs on a platform.
-nick
Dear Nick,
Please find the sh voice DSP.
-HQ#sh voice dsp
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
C549 010 01 g729r8 4.1.41 busy idle 0 0 1/1:15 30 0 6823409/5935
157
to determine where the dsp modules are installed try to issue show inventory command.
You are responding to a 4 yeard old thread. The people involved have since then moved on.
Its still useful information Paolo, which is why they don't delete these threads.
Being answering questions here (including this one) since years, indeed I'm aware of that.
R1# show inventory
really useful command for basic hardware lookup. Thanks
It indeed helped! Thanks a lot
