05-17-2009 12:25 AM - edited 03-15-2019 06:03 PM
We have a customer running CUMC V4 with a remote site across a private leased line. At the remote site we have IP phones and two H323 voice gateways. Users at the remote site can make internal local calls and calls across the WAN. They can make and receive calls through both the H323 gateways in the remote site.
The customer now has a 20Mb Metro-Ethernet MPLS circuit between the two sites and has re-routed the traffic between the two sites from the private leased line to the MPLS circuit.
Following this change, the users at the remote site can still make internal local calls and calls across the WAN. They can make outgoing calls through either of the two H323 voice gateways at the remote site.
The problem is with incoming calls through either of the voice gateways at the remote site. When either of the two remote H323 gateways receives an incoming call, it rings the extension but when the user takes the phone off-hook, the calling party still hears ringing and the called party hears nothing. If the called party places the phone back on-hook, it starts ringing again. If the calling party continues to wait, the call goes to voicemail.
Debugging the H225/245 on the gateway, we see the H225 signalling traffic to the CUCM when the call comes in but when the phone is taken off-hook to answer the call, there is no H225/245 traffic back from the CUCM to complete the call.
If we re-route traffic back across the leased line, it all works fine.
All routing has been thoroughly checked and none of the H323 source bind addresses have been changed. Our next step is to take sniffer traces from each end of the link to analyse the H323.
The only time I have seen something similar was when a firewall in the MPLS cloud decided the H225 traffic was a DOS attack and closed the session but we are assured there are no firewalls in the network.
Has anyone seen anything similar or have any ideas what may be causing the problem.
05-18-2009 12:28 AM
I`m not saying this is it but I had a similar issue with a Nortel and H323 in that if the nortal answered a call from IPT , the IPT phone was justing ringing to it- same but with MGCP set up it was fine . I had to tick, turn off "Wait for Far End H.245 Terminal Capability Set" on the IPT H323 GW then worked ok
05-18-2009 12:28 AM
I`m not saying this is it but I had a similar issue with a Nortel and H323 in that if the nortal answered a call from IPT , the IPT phone was justing ringing to it- same but with MGCP set up it was fine . I had to tick, turn off "Wait for Far End H.245 Terminal Capability Set" on the IPT H323 GW then it worked ok
05-18-2009 12:43 AM
Thanks for your response. I will look into the option. It's strange it only happens over the MPLS but works fine over the leased line. We will not be able to test again until nex Saturday night.
09-27-2013 07:14 AM
Fantastic, saved my day
had the same problem with CUCM 4
Uncking that solved my problem
shameer
