CCME GPickup
Answered Question
May 17th, 2009
Dear All,
I am running CCME 4.2. I only want to dial one extension number to receive group pickup for a number to extensions.
Malik
Correct Answer by Adrian Saavedra about 7 years 9 months ago
Hi Malik,
You will need to configure the pickup-group command under all your ephone-dns.
For example:
ephone-dn 1 dual-line
pickup-group 30
ephone-dn 2 dual-line
pickup-group 30
ephone-dn 3 dual-line
pickup-group 30
ephone-dn dual-line
pickup-group 30
Then you can pickup any call ringing at any phone from any other.
Hope it helps!
Best regards,
- Adrián.
Overall Rating: 5 (2 ratings)
tiger_401 Sun, 05/17/2009 - 14:00
thanks for your response...i will configure it and if there is any issue i will let you know...
tiger_401 Sun, 05/17/2009 - 22:02
Can anybody tell me how i can configure
"Call Pickup, a Single Group for All Cisco CME Phones"
Malik.
Correct Answer
Adrian Saavedra Sun, 05/17/2009 - 22:32
Hi Malik,
For example:
pickup-group 30
pickup-group 30
pickup-group 30
ephone-dn dual-line
pickup-group 30
Hope it helps!
Best regards,
- Adrián.
tiger_401 Sun, 05/17/2009 - 22:56
GREAT!!!!Thanks Mr. Adria. Really appreciate your support....
Malik...
