XConnect on vlan SVI
francisco_1
Level 7
Level 7
I have a 6500 facing my core network and tried to enable L2TPv3 (xconnect) on a vlan SVI but the vc will not come up. the module i am using is WS-X6748GE-TX card. Do i need a SIP module for this to work?
6 Replies 6
Harold Ritter
Francisco,
You indeed need a SIP card (or ES20 card) if you want the SVI to be the termination point for your pseudowire.
Without such a card you can always put the xconect statement on a physical interface or subinterface.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
I am testing ES card, and tried to create a PW from VLAN interface, it does not come up:
PE4#sh mpl l2transport vc
Local intf Local circuit Dest address VC ID Status
Vl290 Eth VLAN 290 10.10.136.129 37123712 DOWN
PE4#sh mpl l2transport vc 37123712 det
PE4#sh mpl l2transport vc 37123712 detail
Local interface: Vl290 up, line protocol up, Eth VLAN 290 up
Interworking type is Ethernet
Destination address: 10.10.136.129, VC ID: 37123712, VC status: down
Output interface: none, imposed label stack {}
Preferred path: not configured
Default path: no route
No adjacency
Create time: 00:00:49, last status change time: 00:00:03
Signaling protocol: LDP, peer 10.10.136.129:0 up
Targeted Hello: 10.10.136.131(LDP Id) -> 10.10.136.129
Status TLV support (local/remote) : enabled/not supported
Label/status state machine : remote ready, LndRru
Last local dataplane status rcvd: no fault
Last local SSS circuit status rcvd: AC DOWN(rx,tx faults)
Last local SSS circuit status sent: no fault
Last local LDP TLV status sent: no fault (withdrawn)
Last remote LDP TLV status rcvd: not sent
MPLS VC labels: local unassigned, remote 340
Group ID: local unknown, remote 0
MTU: local unknown, remote 1500
Remote interface description: ** Test PW with PE4 ES SVI int **
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, seq error 0, send 0
PE4#sh module
Mod Ports Card Type Model Serial No.
2 40 7600 ES+ 7600-ES+40G3CXL JAE1309493P
3 40 7600 ES+ 7600-ES+40G3CXL JAE1309493M
5 2 Route Switch Processor 720 (Active) RSP720-3C-GE JAE12024CGH
6 2 Route Switch Processor 720 (Hot) RSP720-3C-GE JAE1130RD6Z
PE4#sh run int g3/10
Building configuration...
Current configuration : 207 bytes
interface GigabitEthernet3/10
description ** Connected to ISG-2000-2 E1/1 **
switchport
switchport trunk allowed vlan 290,299
switchport mode trunk
speed 1000
service-policy output trunk-policy
end
interface Vlan290
no ip address
xconnect 10.10.136.129 37123712 encapsulation mpls
end
I moved it to physical interface it comes up:
interface GigabitEthernet2/1
no ip address
ip verify unicast source reachable-via any
load-interval 30
speed 1000
isis network point-to-point
isis authentication mode md5
isis authentication key-chain N-ISIS
end
PE4#sh mpls l2transport vc
Gi2/1 Ethernet 10.10.136.129 37123712 UP
PE4#sh mpls l2transport vc 37123712 detail
Local interface: Gi2/1 up, line protocol up, Ethernet up
Destination address: 10.10.136.129, VC ID: 37123712, VC status: up
Output interface: Gi5/1, imposed label stack {16009 340}
Default path: active
Next hop: 10.10.129.53
Create time: 00:00:24, last status change time: 00:00:24
Label/status state machine : established, LruRru
Last local SSS circuit status rcvd: no fault
MPLS VC labels: local 50279, remote 340
Group ID: local 0, remote 0
MTU: local 1500, remote 1500
SSO Descriptor: 10.10.136.129/37123712, local label: 50279
SSM segment/switch IDs: 8426/4098 (used), PWID: 4098
VC statistics:
sankararaman.k
Hi Fran
This should be working, i have seen working in 7600. You can apply xconnect on the VLAN. Can i know the IOS version using on the 6500??
this might help (or confuse)
xconnect on interface VLAN could be working, but as I recall you need OSM/ES cards for uplink.
But using MUXUNI functionality and configuring xconnect on do1Q subinterface should be OK.
http://www.cisco.com/en/US/docs/routers/7600/install_config/12.2SR_OSM_config/mpls_ps368_TSD_Products_Module_Configuration_Guide_Chapter.html#wp1128955
Configuring EoMPLS VLAN Mode for Supervisor Engine 720-Based System
To configure MPLS to transport Layer 2 VLAN packets between two endpoints in a supervisor engine 720-based system, perform the following steps on the provider edge (PE) routers.
Note You must configure Ethernet over MPLS (VLAN mode) on the subinterfaces.
Hi!
We are setting up xconnects from a physical interface and the EoMPLS TE tunnels are connected over vlan interfaces with trunks in both ends.
Do i also have to configure the VLAN mode in someway to get this running?
A lot of our tunnels works perfecly but now when we are setting up new tunnels the incoming unicast traffic does not enter from the physical interface to the VC in both ends.
When doing packet capture from the incoming interface i can see unicast packets coming in but the the VC packet counters doesn't increase.
Multicast traffic are running perfect between the CE's and the cdp neigbour is shown in both ends.
Is there any known issue when connecting EoMPLS with xconnect from a physical interface over a trunk with SVI's?
