How to configure URL-RE-write on CSS
Answered Question
May 17th, 2009
Could you please suggest how to do the url-write to see the url change on the css to get to the different format example:-
I type in https://data.impo.com/dit/core the content rule lokks for the " portion and uses the above service then I want to see that it should go to the webserver it should get it to be redirected to:https://data.impo.com/dit/core/format/servrt
Any help would be appriciated.thanks in advance.
Sum
Correct Answer by Gilles Dufour about 8 years 1 week ago
Sum,
do you terminate SSL on the CSS ?
If not, you can forget rewriting the url... it is encrypted and we can't see it or modify it.
If you terminate SSL traffic, what you can do is intercept the query and send a redirect. Forcing the client to send a new query to the desired url.
You can get sample configuration from:
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a00801de8d6.shtml
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Mon, 05/18/2009 - 00:33
  • Cisco Employee,
Sum,
Gilles.
sumaiyausa Mon, 05/18/2009 - 04:10
Hi Giles,
Thanks for the information provided which i was looking for.
You have been helpfull all the times and we thank you for that.
Sum.
