ACS Appliance 4.2 - Internal database replication Problem
Answered Question
May 18th, 2009
hellow
i'm yunchoul jung in korea
now i'm configuring ACS Appliace 1113 ver4.2
in internal database replication, Primary and secondary ACS server can not repliacate the database because of the default SELF(127.0.0.1) configuration in network configuration.
so i have a guestion how i can replace 127.0.0.1 address to the desired ip address or delete the SELF(127.0.0.1) address
i dont understand a solution procedure in the bellow documentation .
thanks for your help in advance
Problem: 127.0.0.1 is a reserved address
You have two units of ACS SE 1113 and want to replicate the internal database from primary to secondary,
but you notice this error message in the secondary unit:
Inbound database replication from ACS <secondary ACS unit name> denied - shared secret mismatch
When you try to modify the key of AAA Server Self under Network Configuration the error message is
returned.
Correct Answer by Jagdeep Gambhir about 8 years 1 month ago
That is due to a known bug,
Symptom: 127.0.0.1 address appears in ACS and replication fails
Conditions:
Install S/W Acs version 4.2.0.124
*Disable Network Adapter
*Enable Network Adapter
*Navigate to Network Configuration page.
*Should see the AA server IP to be loop back one
Workaround:
For windows: remove the 127.0.0.1 entry
For appliance: backup the database, install ACS on windows, restore, remove
the entry, do a backup and restore it on the appliance
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCso39795
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
ACS does not support distributed deployments in a NAT environment. If a Primary or Secondary address is NAT-configured, the database replication file will indicate shared secret mismatch. Bidirectional replication, wherein an ACS sends database components to and receives database components from the same remote ACS, is not supported. Replication fails if an ACS is configured to replicate to and from the same ACS.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/user/guide/SCAdv.html#wp755988
Correct Answer
Jagdeep Gambhir Fri, 05/22/2009 - 07:09
  • Red, 2250 points or more
Conditions:
Workaround:
~JG
w.iqbal Tue, 05/26/2009 - 06:03
if you want to give desired ip follow this.
1) Connect your acs cable with your system. like normal system connection , without connectivity i never found to change my ip.
2) in console enter
set ip (enter)
give ip ,subnet as it ask.
Done..
Bangash
pakistan
MarekVanco_2 Fri, 04/29/2011 - 10:55
did you manage to resolve his issue? I ahve the same problem? was it a bug as stated above?
This is the version I'm running:
Cisco Secure ACS4.2.0.124
Appliance Management Software4.2.0.124
Appliance Base Image4.2.0.107
Message was edited by: MarekVanco
Devashree Chakr... Mon, 05/02/2011 - 20:15
  • Bronze, 100 points or more
Hello Marek
Yes, there is a know bug. You need to follow the workaround :
Workaround:
thanks
Devashree
