Default Connection timeout
May 18th, 2009
I don't find the info about what are the defaul connection parameters for ASA 8.0 or above when you don't define any Class-map. So For default connection which are the default value like:
Max TCP/UDP connection & Timeouts
Max Embryonic Conn & Timeouts
Max per Client Conn & Timeouts
etc ..
There is CLI command that can I use to diplay the amount of time that is left for timeout here above or to check for a specific connection the parametrisation ?
helenio Mon, 05/18/2009 - 21:53
Hello, I'm thinking connection setting related to CLI command "set connection" where we can define Max connection and embryonic connection. In particular defaul value for traffic that has no Class associated.
