IOS XR Layer 2 internetworking and layer 2 local switching
May 18th, 2009
I have 12410 with iox 3.6.1 and sip 501 with spa-5GE I want to configure layer 2 vpns for internetworking and layer 2 local switching. I search in the command reference and I didnt find the connect command nor internetwork ip under the PW class. can any one tell me how to configure it
Laurent Aubert Mon, 05/18/2009 - 17:45
Here is an example for local switching:
RP/0/1/CPU0:router(config-if)#l2vpn
RP/0/1/CPU0:router(config-l2vpn)#xconnect group local
RP/0/1/CPU0:router(config-l2vpn-xc)#p2p ac1
RP/0/1/CPU0:router(config-l2vpn-xc-p2p)#interface gi0/3/0/0
RP/0/1/CPU0:router(config-l2vpn-xc-p2p)#interface gi0/3/0/1
RP/0/1/CPU0:router(config-l2vpn-xc-p2p)#commit
RP/0/1/CPU0:router(config-l2vpn-xc-p2p)#end
Any-2-Any connection type required 3.8
Laurent.
a_ossama Mon, 05/18/2009 - 23:20
thank a lot Laurent you helped me a lot. I searched a lot in cisco for any example with no hope. so the following is true
local switching supported for gigaeth
any to any local switching supported in 3.8
does also any to any between two different platforms ( XR and 7200) specificaly vlan on XR and atm on 7200 will require 3.8 also ?
thanks in advance
