OSPF Fluctuations every 32 Minutes in CSC Environment
May 18th, 2009
  • Gold, 750 points or more
Hello Experts,
We experience the OSPF Fluctiations every 32 Minutes i.e. configured between PE & 'CSC' Router.
Note: It's a CSC Setup.
Few points are:
1) Last Mile is Healthy
2) OSPF Configuration are Fine
3) No MTU Related issues.
Can someone help in identifying the exact cause for the same.
Best Regards,
Guru Prasad R
Giuseppe Larosa Mon, 05/18/2009 - 04:18
  • Hall of Fame,
    Founding Member
Hello Guru,
each OSPF LSA is refreshed by the original owner every 30 minutes on average, (LSA group pacing waits to collect a group of LSAs to refresh).
A new version of LSAs trigger a SPF recalculation and this might explain what you see.
Hope to help
Giuseppe
guruprasadr Mon, 05/18/2009 - 05:22
Hello Giuseppe,
Thanks for the Reply.
I tried 'LSA Group Pacing' in CSC Router, but the problem was continue to be existing.
Any more help, would be really Appreciable.
Best Regards,
Guru Prasad R
Giuseppe Larosa Mon, 05/18/2009 - 05:36
  • Hall of Fame,
    Founding Member
Hello Guru,
I would suggest you to better define the problem:
what do you mean with OSPF fluctuations?
I may guess you can experience temporary loss of MPLS connectivity but it is a wild guess.
In this case you can try to play with LDP synchronization
see
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/fsldpsyn.html#wp1054554
on in the field of MPLS LDP graceful restart
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_ldp_grace_rstrt_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Hope to help
Giuseppe
