Layer 2 problem with E1 Controller
May 18th, 2009
I have Cisco 3800 router with 2 port E1 controller card ,problem i have is that the 1 port on the controller works fine ,but the other port keeps giving me a TEI_ASSIGNED status when i do a sh isdn stat ,after running Q921 debugs i can see that my router is not responding to SABME messages from the Telco ,any idea what the problem might be ?
iptuser55 Mon, 05/18/2009 - 04:52
  • Silver, 250 points or more
Have you checked the line type -Qsig, DMS etc, CRC4 on/off, Clocking etc. What about the number of channels, . Can you connect the "good circuit" to the faulty port ?
rynard.coetzee Tue, 05/19/2009 - 00:33
Here are the configs from the router ,also when i connect the good circuit to the faulty port the same situation occurs
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
network-clock-select 2 E1 0/1/1
controller E1 0/1/0
pri-group timeslots 1-31 service mgcp
controller E1 0/1/1
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/1/1:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn sending-complete
no cdp enable
paolo bevilacqua Mon, 05/18/2009 - 05:52
  • Hall of Fame,
    Founding Member
Begin posting here output of "show controllers E1".
rynard.coetzee Tue, 05/19/2009 - 00:37
Here are the outputs from sh controllers e1 and sh isdn status ,the 0/1/1 is the faulty port
XXXX#sh controllers e1
E1 0/1/0 is up.
Applique type is Channelized E1 - balanced
Cablelength is Unknown
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20071011, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (280 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
16391 Line Code Violations, 16 Path Code Violations,
0 Slip Secs, 1 Fr Loss Secs, 2 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 2 Severely Err Secs, 8 Unavail Secs
E1 0/1/1 is up.
No alarms detected.
Data in current interval (282 seconds elapsed):
2138015 Line Code Violations, 49 Path Code Violations,
83 Slip Secs, 4 Fr Loss Secs, 8 Line Err Secs, 0 Degraded Mins,
81 Errored Secs, 0 Bursty Err Secs, 7 Severely Err Secs, 647 Unavail Secs
XXXXX#sh isdn stat
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 25
%Q.931 is backhauled to ME 0x0700 on DSL 1. Layer 3 output may not apply
ISDN Serial0/1/1:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
Active dsl 1 CCBs = 0
Number of L2 Discards = 0, L2 Session ID = 3
Total Allocated ISDN CCBs = 0
paolo bevilacqua Tue, 05/19/2009 - 08:20
  • Hall of Fame,
    Founding Member
Both ports are experiencing slip errors.
configure:
network-clock-participate wic 0
network-clock-select 1 e1 0/0/0
network-clock-select 2 e1 0/0/1
controller e1 0/0/0
clock source line primary
And check if any improvement.
Also try swapping circuites to interface, see if problem stays with port or circuit.
rynard.coetzee Tue, 05/19/2009 - 22:52
I have configured the clock source line primary command under the controller ,but still no change. I have also tried swapping the circuits ,the problem stays with the port.
rynard.coetzee Tue, 05/19/2009 - 23:14
Oops ,i found the problem guys ,sorry it was my own stupidity ,i had forgotten to configure the port in CUCM ,so it had a blank config in CUCM.
