Unity and SMTP
Answered Question
May 18th, 2009
Is it needed to have SMTP service running on Unity when it works within Exchange ?
regards
Correct Answer by Ginger Dillon about 8 years 6 days ago
Hi -
I believe SMTP is installed as part of the IIS suite when you prep the Unity server - IIS, SMTP, and W3SVC. You can go to Unity server control panel - add/remove programs and select the Windows components on the left side of console. Select IIS and you should be able to see the options for components.
Ginger
Overall Rating: 5 (1 ratings)
Tray Stoutmeyer Mon, 05/18/2009 - 06:17
  • Cisco Employee,
It is installed and running on every one of my Unity servers so I would assume this gets installed by default.
Tray
Correct Answer
Ginger Dillon Mon, 05/18/2009 - 13:49
  • Blue, 1500 points or more
Hi -
Ginger
