Paolo Bevilacqua Mon, 05/18/2009 - 05:54
  • Hall of Fame,
    Founding Member
Not that I'm aware. If you use a GK however, all the regular CAC features should be applicable.
Adrian Saavedra Mon, 05/18/2009 - 06:21
  • Gold, 750 points or more
CME can do a limited amount of CAC itself without a gatekeeper, either by limiting the number of simultaneous calls associated with each dial peer or by using RSVP.
But, per dial peer call counting doesn't work well if you're using more than one dial peer per WAN link, and RSVP requires end to end support within your network.
Hope it helps!
Best regards,
- Adrián.
dinorubio Tue, 07/05/2011 - 09:41
With CUCME 8.5 is it possible to have CAC ?
I've read SRND but no reference to that is made...
Thanks for helping,
Dino
