right Java Version for CiscoWorks 6.0 and later
Answered Question
May 18th, 2009
I was wondering if someone please advise on what Java version I need to run Cisco works 6.0 nad later without error? as is i canot run the campus manager at all given the unsupported java version on my pc. I am acessing this application via brower - IE7.
I remember something from a few years ago, Java version 6.4.1.xx if I am not mistaken!?
Masood
Correct Answer by Joe Clarke about 7 years 8 months ago
Yes, 1.4.2_15 is the only version of Java that will work with this version of Campus. You will need to have your administrator uninstall other JVMs on your client, and install the 1.4.2_15 from the CiscoWorks server.
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 05/18/2009 - 06:40
There is no CiscoWorks 6.0. What version of Campus Manager do you have?
masoodabooali Mon, 05/18/2009 - 06:49
Thanks for your prompt response. Well I tried to run it and it is asking for java version: SE V1.4.2_15 but installation fails because I don't have admin rights on my PC?
License Info:
UPGRADE Copy
Version & Patch Level: 4.0.9
Installation Date:
Fri Jul 01 16:52:51 EDT 2005
LMS2.6 01 Jul 2005
Masood
Correct Answer
Joe Clarke Mon, 05/18/2009 - 07:12
masoodabooali Mon, 05/18/2009 - 10:36
Ho wabout the IE? it also tells me that I am using unsupported IE?
We are using IE7!?
I also get certificate error? -usually certificate errors don't prevent the application from working except that it is kind of annoying!
Please advise.
Masood
Joe Clarke Mon, 05/18/2009 - 10:58
IE 7.0 support was not added until LMS 3.0. LMS 2.6 only supported IE 6.0 and Mozilla 1.7.
The certificate error occurs because you are using a self-signed certificate. You can either import the certificate into your browser, or purchase a CA signed certificate, and install it into LMS.
