ssh v2 and CAT OS version on Cisco 6500 series switches?
May 18th, 2009
hello all,
I have been trying to find out which CAT OS version on Cisco Swithc 6509 (or 6500 series) switches, will support ssh v2?
can some on eplease point me to right direction please?
Masood
glen.grant Mon, 05/18/2009 - 07:07
  • Purple, 4500 points or more
Looks like it might be available in code version 8.3 or later .
masoodabooali Mon, 05/18/2009 - 07:09
Yes they have. I am sure that it is supported for one of th eversions of 8.x but it is the .x part of it that I am not sure and I hav enot benable to find out so far!?
Masood
masoodabooali Mon, 05/18/2009 - 07:16
thanks. where did you find this information if I may ask please?
Masood
masoodabooali Mon, 05/18/2009 - 11:04
Switch> (enable) sh ssh
Id Protocol Cipher HMAC State PID
1 * V2 AES256-CBC HMAC_SHA1 SSH_SESSION_OPEN PID number
Id Userid Host
1 * Username x.x.x.x
SSH server mode : V1 and V2
you see both modes : v1 and v2 is currently running!
regards,
Masood
masoodabooali Mon, 05/18/2009 - 11:02
based on the pdf file, only 8.6(x) supports ssh v2 but here I have a switch software version 8.5(9) and it supports v1 and v2!?
then what was teh article saying?
it maybe that 8.6 and later don't support v1 at all as oppose to this 8.5(9) version that supports both v1 and v2!?
isn't it?
WS-C6513 Software, Version NmpSW: 8.5(9)
Masood
glen.grant Mon, 05/18/2009 - 07:26
Catos release notes for 8.X code . Then just use the find function on your browser and search for SSH .
masoodabooali Mon, 05/18/2009 - 11:15
Secure Shell Version 2 Server ?
this means on any switch that i want to use ssh v2, I use this command? as long as I can see the mix mode for v1 and vb2 as I posted above.
Please advise.
Masood'
