Very basic ACE config question
May 18th, 2009
Hi all
I've just got my hands on my first Cisco ACE and I'm trying to configure it with two contexts (Admin+Web) in a simple 1 arm mode.
I can successfully reach the management ip x.x.0.16 (VLAN 1000 in the Admin context), but I cannot ping the ip (y.y.0.8) on VLAN 100 (Web context). Gi1/2 is connected to a trunk port on a switch, and there are other hosts that are able to communicate successfully within this VLAN.
When I ping from the ACE to the gateway y.y.108.2, I do not get a response; however, the correct ARP entry does show up in the ARP table.
When I ping from y.y.108.2 to the ACE, I get a timeout. In addition, the ARP entry remains 'Incomplete'.
Any ideas? Attached is the config for both contexts.
dario.didio Tue, 05/19/2009 - 02:39
  • Silver, 250 points or more
some remarks:
You say "I can successfully reach the management ip x.x.0.16 (VLAN 1000 in the Admin context), but I cannot ping the ip (y.y.0.8) on VLAN 100 (Web context)."
In your config, the address in VLAN100 in the web context is not y.y.0.8 but y.y.108.8.
In your config, the gateway is not y.y.108.2 but y.y.108.1.
Can you verify this if it are just typos?
Can you post the configuration of you switchports? access in VLAN1000 and trunk in VLAN100.
A assume these VLANs exist in your network?
Dario
