problem with the NM-16ESW-dynamipsGUI
May 18th, 2009
I am trying to do a simple trunking or etherchannel between two switches. I created an svi under vlan 1 with an ip add 12.1.1.1/24 and an svi under vlan 1 on switch 2 ip add 12.1.1.2/24. I did a trunk on a port that connects the switches together. I tried to ping and no success. I also created a static route but still no response. I did a debug ip packet and the following message came up :
SW2#ping 12.1.1.1
Sending 5, 100-byte ICMP Echos to 12.1.1.1, timeout is 2 seconds:
*Mar 1 00:28:19.119: IP: tableid=0, s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), routed via RIB
*Mar 1 00:28:19.123: IP: s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), len 100, sending
*Mar 1 00:28:19.127: IP: s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), len 100, encapsulation failed.
*Mar 1 00:28:21.119: IP: tableid=0, s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), routed via RIB
*Mar 1 00:28:21.123: IP: s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), len 100, sending
*Mar 1 00:28:21.127: IP: s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), len 100, encapsulation failed.
*Mar 1 00:28:23.119: IP: tableid=0, s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), routed via RIB
*Mar 1 00:28:23.123: IP: s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), len 100, sending
*Mar 1 00:28:23.127: IP: s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), len 100, encapsulation failed.
*Mar 1 00:28:25.119: IP: tableid=0, s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), routed via RIB
*Mar 1 00:28:25.123: IP: s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), len 100, sending
*Mar 1 00:28:25.127: IP: s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), len 100, encapsulation failed.
*Mar 1 00:28:27.119: IP: tableid=0, s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), routed via RIB
*Mar 1 00:28:27.123: IP: s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), len 100, sending
*Mar 1 00:28:27.127: IP: s=12.1.1.2 (local), d=12.1.1.1 (Vlan1), len 100, encapsulation failed.
Success rate is 0 percent (0/5)
I also tried these show commands
SW2#sh int f2/3
FastEthernet2/3 is up, line protocol is up
Hardware is Fast Ethernet, address is cc07.098c.f203 (bia cc07.098c.f203)
Description: To SW1 F2/3
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
Last input 00:00:01, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier
Rack1SW2#sh int f2/3 trunk
Port Mode Encapsulation Status Native vlan
Fa2/3 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa2/3 1-1005
Port Vlans allowed and active in management domain
Fa2/3 1
Port Vlans in spanning tree forwarding state and not pruned
Fa2/3 1
Rack1SW2#sh run int f2/3
interface FastEthernet2/3
description To SW1 F2/3
switchport mode trunk
end
IOS version : C3640-IS.extracted.bin
Rack1SW2#sh ver
Cisco IOS Software, 3600 Software (C3640-JK9O3S-M), Version 12.4(10a), RELEASE SOFTWARE (fc2)
Technical Support: http://www.test4actual.com
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 11-Oct-06 20:52 by prod_rel_team
ROM: ROMMON Emulation Microcode
ROM: 3600 Software (C3640-JK9O3S-M), Version 12.4(10a), RELEASE SOFTWARE (fc2)
Manish Prasad Wed, 05/20/2009 - 11:38
Are you using the same encapsulation type on both the trunk interface i.e. DOT.1Q or ISL.
Prasad
solpandor Tue, 05/26/2009 - 03:01
Hi there
on SW2, enter the command: switchport trunk encapsulation dot1q
try that.
