ACL question: Explicit deny any any not working?
May 18th, 2009
I'm pretty familiar with ALCs, and understand that every access list has an explicit deny any any, so if you just have an "empty" access list it will block all traffic.
I just added two extended access lists to a physical interface, but left them empty. They don't appear to be blocking any traffic??? Are there some cases where explicit deny any any isn't present??? Is there a case where an access-lists on another interface can 'override' this ACL???
thanks, Simon
simonwynn Mon, 05/18/2009 - 09:00
I actually applied two access lists: one IN and one OUT. No idea what the problem is.
Here is the interface with just the IN (did also try In and OUT):
interface FastEthernet0/0
description DMZ$FW_INSIDE$$ETH-LAN$
ip address
ip access-group dmz in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
and the empty ACL:
ip access-list extended dmz
Jon Marshall Mon, 05/18/2009 - 09:07
The explicit dent any any is true only when the access-list is not empty. If there is at least one entry in an acl then you are correct in what you say but an empty acl will allow all traffic through.
I believe some of the earlier IOS versions did indeed block traffic with an empty acl but this is definitely no longer the case.
simonwynn Mon, 05/18/2009 - 09:51
Thanks Jon - I thought I was going crazy. A lot of online references for ACLs still say empty ACLs will block, so that's what tripped me up.
simonwynn Mon, 05/18/2009 - 09:55
One other question: Do ACLs take effect immediately, or is there any instance where I need to do something to make them take effect??? - Simon
