VPN Clients migration to new public IP
May 18th, 2009
I'm looking for elegant solution to migrate VPN Clients to new public IP.
I have PIXs (public IP x.x.x.1) and Concentrator (x.x.x.2) to be replaced with ASA. All VPN Clients (~200 users) preconfigured with x.x.x.2.
What is the best way (minimum impact) to “combine” PIX and Concentrator in this case?
I see couple options here:
1. reconfig clients with new IP (manually or to push new config);
2. Config x.x.x.2 on ASA, but I do not think it's possible to have IPs from same network on different interfaces;
3. Is there “forward IP to IP” option?
4. Have ASA and Concentrator running and to reconfig end users manually
5. Subnet public network.
What do you think?
S
Farrukh Haroon Sun, 05/24/2009 - 05:56
  • Red, 2250 points or more
First check if everything is working fine on the ASA, by testing it with 2-3 clients (preferably different OS like XP,Vista etc.)
I guess you don't want to change the configuration of the VPN clients (recommended), schedule a downtime and shift the IP from the VPNC to the ASA. If something goes wrong, just unplug the ASA and connect the VPNC back until you fix things :)
That said, its not so difficult to email/publish a new .pcf file for users. Just make sure your current VPN client version is compatible with the ASA:
http://www.cisco.com/en/US/docs/security/asa/compatibility/asa-vpn-compatibility.html
Please rate if helpful
Farrukh
bamnocadmin Wed, 05/27/2009 - 04:37
hello,
You said "shift the IP from the VPNC to the ASA". How do I assign, for example, 10.10.10.2 to ASA interface if I already have 10.10.10.1 on "outside"?
Thanks.
Farrukh Haroon Wed, 05/27/2009 - 05:17
Can't you change it from 10.10.10.2 to 10.10.10.1?
Farrukh
