Tcl Script
will.alvord
Level 5
Level 5
I have been unable to find a sample Tcl script which will play a "your call may be monitored or recorded" message to all inbound callers prior to sending the caller to the dialed number. If anyone has a similar script to share or can point me in the right direction I would appreciate it very much.
thanks,
Will
paolo bevilacqua
You can see for example how B-ACD/AA does.
If you need to have a custom script developed, contact me at the address present in my profile.
Thanks! I'll give it a shot. A couple of questions though. All of the samples that I've seen reference CME/CUE. I can run a Tcl script on a gateway without CME right? I can point a dial-peer to the script with the service command?
My second question is how do I grab the calling number and called number? There must be either some sort of pre-defined variables or a function that returns that data right?
thanks again,
Will
Yes, and yes.
All the call variables are explained in the manual "tcl/ivr programming guide" that is freely available for download.
