Multiple ADSL Links in Active Mode
May 18th, 2009
We have 2 Internet Routers with 2 ADSL Ports on individual routers.
Attached n/w diagram will give you an idea of the setup.
The requirement is: all the time 4 ADSL to be used for Internet accessing purpose.
ASA is in single-context mode. On Core switch OSPF is running.
Can someone suggest the necesary changes to be done at gateway level??
paolo bevilacqua Mon, 05/18/2009 - 12:49
  • Hall of Fame,
    Founding Member
That is not a very simple setup.
I recommend you hire a reputable consultant for the proper configuration.
