clns router isis tag command is not allowed
May 18th, 2009
the current version dont allow configure the command "clns router isis dcn" in a interface and asociate to vrf.
the release is 12.2(33)SRC3.(7609OSR)
I want to know if have another way for configure this?
interface Vlan350
description BSS O&M
ip vrf forwarding o&m
ip address
no ip redirects
no ip unreachables
logging event link-status
standby 106 ip
standby 106 timers msec 300 1
standby 106 preempt
clns router isis dcn (dont allow this command)
service-policy input QoS-LAN-O&M
Laurent Aubert Mon, 05/18/2009 - 17:19
CLNS is not supported if ip vrf forwarding is configured. Only ISIS for IP is supported
Giuseppe Larosa Thu, 05/21/2009 - 11:58
Hello Alfredo,
to carry CLNS over MPLS VPN I used point GRE tunnels end to end between CE nodes.
you need to disable hello padding on GRE interface and you should use a reduced clns mtu to make it to work
Hope to help
apratt2009 Mon, 06/01/2009 - 10:14
Hello Giuseppe,
can you send a example configuration or a link how to make this config ?
Giuseppe Larosa Mon, 06/01/2009 - 10:35
Hello Alfredo,
we moved the CLNS to the CE node.
We built a point to point GRE tunnel from CE to remote CE node end to end
CE1--PE1 --- MPLS cloud --- PE2 -- CE2
peers with PE1 and CE1-PE1 link is the VRF access link.
CE1 has an IOS version that supports IPv4 and CLNS routing
int tunnel 100
tunnel source CE1:ipaddr
tunnel destination CE2:ipaddr
clns router isis
see the following:
router isis
net 39.380f.0065.0064.0000.0102.0304.0200.0000.0009.00
is-type level-1
no hello padding point-to-point
lsp-mtu 1000
interface Tunnel471
no ip address
no ip directed-broadcast
ip route-cache distributed
clns mtu 1400
clns router isis
isis priority 70 level-1
tunnel source FastEthernet5/0/0.4
tunnel destination
tunnel checksum
this worked for us and allowed to integrate in an MPLS VPN a management network where there is SDH equipment using CLNS to communicate with SDH manager servers.
Hope to help
drubiogr Mon, 06/01/2009 - 10:25
AFAIK we don't support CLNS routing in vrf's.
I've tried to configure it and this is what I get,
PE-Massa(config-if)#clns router isis test
%CLNS: Cannot enable CLNS for non-default VRF interface
I hope it helps.
