can't ping from inside with asa 5520
May 18th, 2009
I configure ASA 5520 to protect my network, but i can't go to the internet from my inside.
i can ping outside address frome outside interface from asa but not from inside .
ciscoasa# show run
: Saved
ASA Version 7.0(8)
hostname ciscoasa
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
interface GigabitEthernet0/0
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
nameif OUTSIDE
security-level 0
ip address
interface GigabitEthernet0/2
no nameif
no security-level
<--- More --->
no ip address
interface GigabitEthernet0/3
nameif inside
security-level 100
ip address
interface Management0/0
no nameif
no security-level
no ip address
ftp mode passive
pager lines 24
mtu inside 1500
mtu OUTSIDE 1500
no failover
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
global (OUTSIDE) 1 interface
nat (inside) 1
route OUTSIDE 1
<--- More --->
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
username cisco password 3USUcOPFUiMCO4Jk encrypted
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet inside
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
<--- More --->
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
: end
Overall Rating: 5 (1 ratings)
Fernando_Meza Tue, 05/19/2009 - 03:43
You most likely need to enable icmp inspect in order to get icmp through the firewall. This is disabled by default
hostname(config)# policy-map global_policy
hostname(config-pmap)# class inspection_default
hostname(config-pmap-c)# inspect icmp
hostname(config-pmap-c)# exit
You should be able to connect to the Internet though (of course assuming your DNS settings are correct.
I hope it helps .. please rate helpful posts
