unity serial number
Answered Question
May 18th, 2009
how do i get the serial number off a win 2000 unity server? i tried the wmic csproduct command and the HP management tool and it doesnt work.
Correct Answer by Adrian Saavedra about 8 years 6 days ago
Try this: copy the following in Notepad and save it in Unity's desktop as .vbs file.
strComputer = "."
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
Set colBIOS = objWMIService.ExecQuery _
("Select * from Win32_BIOS")
For each objBIOS in colBIOS
Wscript.Echo "Manufacturer: " & objBIOS.Manufacturer
Wscript.Echo "Serial Number: " & objBIOS.SerialNumber
Next
Once finished, double click and should show you the Serial number.
Hope it helps, if it does please rate.
Good luck,
- Adrián.
Overall Rating: 5 (2 ratings)
Correct Answer
Adrian Saavedra Mon, 05/18/2009 - 16:39
  • Gold, 750 points or more
strComputer = "."
Next
Good luck,
- Adrián.
