TFTP WITH WRV210
May 18th, 2009
I have a WRV210 Router. I am unable to access the web interface but the DHCP Server for the router is operational. I have tried to reset to defaults but this does not work. I have also tried to upgrade the firmware and restore a configuration file via tftp but it times out. Please advise if there is another way to recover this router.
Te-Kai Liu Tue, 05/19/2009 - 13:02
  • Gold, 750 points or more
Before you run the TFTP client, did you set your PC to have static ip address in the 192.168.1.x subnet, e.g. 192.168.1.100?
dhemsley25 Tue, 05/19/2009 - 13:40
Yes I did all this already. I can ping the gateway ip address of 192.168.1.1 but i cannot tftp the backup image file for the router nor the firmware upgrade.
Te-Kai Liu Tue, 05/19/2009 - 13:46
Well, you might need to call the Tech Support or your reseller for RMA if the device is still under warranty.
