SVI interface on cisco 7513
abhay.avadhani
Can we create a Vlan interface ( SVI ) on cisco 7513.
Richard Burts
Abhay
Perhaps there is an issue of terminology involved here. If the question is specifically can you configure interface vlan n, then the answer is that no you can not configure a vlan interface on the 7513. If the question is can you configure the 7513 to communicate with vlans then the answer is that you should be able to configure the switch port that connects to the 7513 as a trunk and to configure the FastEthernet interface on the 7513 to support trunking using subinterfaces on the the FastEthernet for each VLAN that you want to communicate with.
Rick
Rick
