Directory number presentation
May 18th, 2009
It would be of great help if someone knows how to avoid presenting a number for internal phone calls. A specific team would like to present the team name only (not their extension number)
Overall Rating: 5 (1 ratings)
Jaime Valencia Mon, 05/18/2009 - 20:25
  • Cisco Employee,
  • Hall of Fame,
    2011
Since there is no mention of what you're using i'll assume CUCM 7.0
Use a translation pattern as a middle man for the calls and configure the calling party number presentation as restricted
java
if this helps, please rate
j.bedoya Tue, 05/19/2009 - 16:50
Thanks Java,
It is ok to assume it is CUCM 7.0. Your suggestion implies removing the "Internal" partion from the IP phone CSS (as it is for internal calls). It will work for normal phones but not for Extension Mobility phones. Is that right?
Jaime Valencia Tue, 05/19/2009 - 18:31
  • Cisco Employee,
  • Hall of Fame,
    2011
why wouldn't it work for EM???
You have a line CSS and a device CSS as you have with your phone.
Just instead of A calling B
A calls TP, TP calls B.
A CANNOT reach B directly, the translation patterns hides whatever info you want
java
j.bedoya Tue, 05/19/2009 - 19:09
Hi Java,
Thanks again for your input.
In order for A not to reach B, we have to do the following:
Remove Partition B from A CSS at the device level and add the "man in the middle" partition to A Device CSSs. In this case, it will work only if the user is logged in on a particular physical phone. As soon as the user goes to a different phone it won't work.
I have been thinking on how to do this at the line level, but because at the device level they can call "any where" and any extension is more specific than any pattern to call the "man in the middle" translation pattern, it won't work :(.
am I right?
