Terminal Server Connectivity Problem
May 18th, 2009
I have a 2811 Series Terminal Server, I have configure It few days back every thing is working fine, I am able to telnet the connected device, session also created during that. but yesterday i am unable to telnet the device. while telneting i am getting below error.
HYD-TERM-SRV#r1
Trying R4 (10.136.62.2, 2046)... Open
*May 18 09:03:20.363: rx dma stop failed
*May 18 09:03:20.375: rx dma start failed
*May 18 09:03:20.387: rx dma start failed
While reloading I am getting below error
*May 18 09:22:44.427: rx dma start failed
*May 18 09:22:44.427: tx dma start failed -Traceback= 0x404F5148 0x404F89D0 0x404FA36C 0x404FA504 0x402680C8 0x40A6E554 0x40A6E7EC 0x413CADFC 0x413CADE0Unrecoverable Rx error on channel 10
before comming to any conclusion I have changed the slot of the HWIC-16A card also change the Octal cable too. After doing all these i am getting the same problem. Can any one suggest what is the problem.
Is it a Hardware Problem ( need to replace the HWIC CARD)Or Software Problem
For your referance I am attaching the Sh run file.
