7911 Soft key
May 18th, 2009
Dear all,
I am running CCME 7.1. As we know that cisco ip phone 7911 have default soft keys i.e.
Redail NewCall Msgs more
Is there any possibility that i can change the sequence of the soft keys, if yes then please let me know how is it possible. I will really appreciate if anyone can send me the sample configuration as well.
Similarly i need this thing to be done for 7970.
Awaiting your reply.
Malik.
Overall Rating: 5 (1 ratings)
nesharm2 Mon, 05/18/2009 - 22:30
  • Bronze, 100 points or more
I found this from one of Rob's Post
1. enable
2. configure terminal
3. ephone-template template-tag
4. conference add-mode [creator]
5. conference drop-mode [creator | local]
6. conference admin
7. softkeys connected {[Acct] [ConfList] [Confrn] [Endcall] [Flash] [HLog] [Hold] [Join] [LiveRcd] [Park] [RmLstC] [Select] [TrnsfVM] [Trnsfer]}
8. softkeys hold {[Join] [Newcall] [Resume] [Select]}
9. softkeys idle {[Cfwdall] [ConfList] [Dnd] [Gpickup] [HLog] [Join] [Login] [Newcall] [Pickup] [Redial] [RmLstC]}
10. softkeys seized {[CallBack] [Cfwdall] [Endcall] [Gpickup] [HLog] [MeetMe] [Pickup] [Redial]}
11. exit
12. ephone phone-tag
13. ephone-template template-tag
14. end
Cisco Unified Communications Manager Express System Administrator Guide
Configuring Conferencing
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1017618
