Control Outgoing Calls on selective PRI lines
May 18th, 2009
I have a setup as below:
2 PRI lines are terminated on the Cisco Gateway.
The gateway is connected to a CCM 5.0.
My requirement:I want all outgoing calls should be dialed out from a Particular PRI based on some logic.
How can I control the outgoing calls to be dialled out from a particular PRI based on my choice.
acharyr123 Mon, 06/01/2009 - 10:54
You can do it under Route Group...
For your hint...
1. Register both the pri in the CCM.
2. Say PRI1: E1 0/1/0
3. Say PRI2: E1 0/1/1
4. Under Route Group select Top-Down in the selection criteria. Select 1st PRI on the Top & 2nd PRI then...
5. Means..alloutgoing calls will be thrown to 1st PRI. If 1st PRI is down/not available, calls will be routed via PRI2.
Rate if it helps..
Pranjol Saikia Tue, 06/02/2009 - 21:44
I want to control the outgoing calls,ie I want my CUAE based application to chose (based on some business logic) the PRI line through which the call should go
