Deleting user account does not delete "SMTP Address"
A "SMTP address" is created in the format of [email protected] for every subscriber that is added. When a user is deleted, the “SMTP address” does not seem to get deleted. If you attempt to re-create the same user after you have deleted it, the “SMTP address” becomes [email protected]. If you try to change it back to [email protected], a message indicate that the SMTP address is already exists.
Does anyone know how to delete the SMTP address for subscriber? I'm running Unity Connection 7.0.2.10000-38
Dennis Mink Wed, 05/20/2009 - 04:33
  • Blue, 1500 points or more
Are you pointing to an external exchange server? in other words can you explictly delete the mailbox first?
