Install UCCX remotely
Answered Question
May 18th, 2009
Can UCCX be installed remotely? Cisco Document clearly mentions not to use VNC/PCAnywhere/iLO/RDP, however for the CRS troubleshooting one of the methods mentioned is VNC.
Does using VNC for install, really have any impact?
Thanks.
Correct Answer by Chris Deren about 7 years 9 months ago
You can safely use VNC for installation.
Chris
Overall Rating: 3 (3 ratings)
iftikharsyed_2 Tue, 05/19/2009 - 19:14
we used VNC to install UCCX on our test machine and it works fine.
hth,
Iftikhar Ahmed
slavr Wed, 05/20/2009 - 03:21
I have done some installations/upgrades using VNC and it have never caused any problems for me...
\Søren Lavard
