Unity 4.0.5 "Caller system transfer issue"
May 19th, 2009
Guys,
I am having a strange problem with unity caller system transfer. I have setup a CH for auto attendant. I have configured key mappings to send call to caller system transfer. But each time I enter the extension to be xfered to, unity says "you cannot be tranferred to this extension"
When I use the same extension on "attempt transfer for operator, ring subscriber extension" the call goes through. So I do not have a CSS, partiton issue.. Is there something that needs to be done to allow caller system transfer.
Overall Rating: 5 (2 ratings)
Ayodeji Okanlawon Tue, 05/19/2009 - 10:09
Rob,
After lots of poking around, I actually figured out it was this!. Up until this morning, I thought there was just the default transfer restriction table and thats the one I was looking at, till I stimbled on this one. +5 point for your excellent and as usual helpful response
Thanks. Good to kow you are having fun :)
Tana Franko Tue, 05/19/2009 - 09:06
(Oops, sorry, I missed Rob's response and gave the same answer... anyway, here are links to the 4.0(5) version of the guide.)
It sounds like you need to check the restriction table that governs caller system transfers, CS_Default_System_Transfer.
Here's a link for info on caller system transfers in 4.0(5):
[with Exchange] http://www.cisco.com/en/US/docs/voice_ip_comm/unity/405/administration/guide/ex/sag_0045.html#Setting_Up_System_Transfers
[with Domino] http://www.cisco.com/en/US/docs/voice_ip_comm/unity/405/administration/guide/dom/sag_0045.html#Setting_Up_System_Transfers
You can find a chapter on restriction tables in the same guide...
