Same PIN in Unity and UCM
May 19th, 2009
is it possible the keep the PIN in Unity and UCM synchronous?
Jaime Valencia Tue, 05/19/2009 - 06:30
No, the directory from CUCM and Unity is not connected and does not replicate information between them.
The only way is to manually change both to the same.
if this helps, please rate
David Wagner Tue, 05/26/2009 - 06:02
ok, so i've read it's possible to change the PIN in the sql database. Does anyone know, in which database and table?
David Wagner Mon, 12/07/2009 - 08:24
is it possible between "unity connection 7.x" and "ucm 7.x"?
If not, is it possible to change the PIN in unity connection by axl? So, then i could change the pin in both systems with an external application?!
