please help vpn client and router
Answered Question
May 19th, 2009
Hi all,
I want to stablish a vpn between my PC (with VPN Client version 4.8.02.0010) and a remote router (Cisco 2811)with IOS software release 12.4(9)T7 and the following configuration
aaa new-model
aaa authentication login VPNCLIENT local
aaa authorization network VPNGROUP local
username test password hello
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group 3000client
key cisco123
dns 62.42.230.24
domain cisco.com
pool ippool
crypto ipsec transform-set MYSET esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set MYSET
crypto map clientmap client authentication list lista
crypto map clientmap isakmp authorization list grupo
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
ip address 192.168.4.1 255.255.255.0
ip nat inside
load-interval 30
ip local pool ippool 192.168.4.100 192.168.4.200
no ip classless
ip route 0.0.0.0 0.0.0.0 62.43.195.100
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 102 interface FastEthernet0/0 overload
access-list 102 permit ip 192.168.4.0 0.0.0.255 any
line con 0
line aux 0
line vty 0 4
privilege level 15
transport input telnet
line vty 5 15
privilege level 15
When I connect to the public IP address of the router every thing is all right and status is Connected. But I don't have connectivity to internet and I can only ping 192.168.4.1 but no others IP adress from this range.
I would appreciate any kind of kelp.
Overall Rating: 5 (2 ratings)
usuario0001 Tue, 05/19/2009 - 06:59
Thank you very much. Now it works!
But I'm trying to connect to a PC via remote desktop and I can't. Could you tell me what do I have to add to the router configuration.
Correct Answer
You need to make sure that your internal traffic going to the VPN client is NOT being NATT'd.
You need to re-write acl 102 to something like:-
access-list 102 deny ip 192.168.4.0 0.0.0.255 192.168.4.0 0.0.0.255
HTH>
