AXL: subscribeCallingSearchSpace for users
Answered Question
May 19th, 2009
we use extension mobility for all users, so we have to use the SubscribeCSS inside the end-user settings. (the subscribeCSS for the phone only works without EM-Login).
We had a look at the documentation but, this is not part of AXL to set subscribeCSS for users (add-/updateUser).
Any help welcome.
With kind regards
Axel
Correct Answer by dhook about 8 years 2 months ago
It seems this field have'nt made it into the API yet. The information about which css a user has is stored in the enduser table in the field "fkcallingsearchspace_restrict" as a guid. You could use executeSQLUpdate to put the information in there.
Kind regards,
//Dan-Anders
Overall Rating: 5 (1 ratings)
Correct Answer
dhook Tue, 05/19/2009 - 03:33
Kind regards,
//Dan-Anders
schemberg Tue, 05/19/2009 - 03:35
Hi Dan,
thank you for your reply, I will have a look at.
Axel
