Customize 7921
May 19th, 2009
Hi all,
Somebody knows if in 7921 the option mute is can disable?
It is possible in the 7921 phone, change the button left and put the tranfer option
Thanks a lot!
nesharm2 Fri, 05/22/2009 - 05:47
  • Bronze, 100 points or more
Is there a softkey template that you hav e assigned for 7921
I will have to test it on MOnday and then I can give you confirmed answer.
Meanwhile if you want you can play around with softkey template
