05-19-2009 02:22 AM - last edited on 03-25-2019 07:50 PM by ciscomoderator
Dear all,
I have jkust started to work with CTI ports in a CCM 6.1(2) cluster.
I have installed the Cisco TAPI service provider (TSP) plugin in a W2003 server machine (OS language is Spanish).
I have created an application user in CCM and add it to all the user groups related to CTI matters.
I have also created 2 CTI ports in the CCM and associate them to this user. At this point they are not registered in the CCM.
In the server I have configured TSP to connect to the CCM using this user. The CTI ports are still unregistered.
Then in the Windows dialer in the server I try to perform a call using this ports, but they are not listed as a line in the dialer. I suppose that this is logic as they are not registered.
I would be very grateful if you could let me know more about how the registration proccess of a CTI port works in order to look for the possible causes.
Until now the only CTI ports in the system were created by UCCX, and they are registered correctly.
Thanks in advance for your collaboration.
Best regards,
Amaia Lesta
05-21-2009 07:59 AM
Hi Amaia,
if u intsall the tsp in ur pc? same problem
make sure cti ports r associated and user belongs to CTI controlled group.
06-10-2009 02:34 AM
Dear Gogasca,
Thank you very much.
In the end I realised that it was a basic communication problem. There was a firewall limitation between UCCX and CCM and that's why the communication was not working.
Sorry for the unnecessary question in this forum.
Best regards,
Amaia
