adding names to incoming calls
May 19th, 2009
We are using 2 CCM's with version 4.1(3)sr3b connected to 2 QSIG Gateways using 2 PRI lines.
I have had a request to configure the Callmanager in such a way that persons being called from three specific external numbers (79551, 79554 and 79552) can also see the name associated with those numbers. Those names are not being sent by the telco; is it possible to add names to those incoming numbers using the Callmanager?
If yes, how would I go around implementing this?
Regards, Marvin Woods
Overall Rating: 3 (1 ratings)
paolo bevilacqua Tue, 05/19/2009 - 08:12
  • Hall of Fame,
    Founding Member
Are you using mgcp or h323 ?
felton_nl Tue, 05/19/2009 - 23:25
Good morning,
used product: Cisco 2811
used protocol: MGCP
If you need more info, let me know.
paolo bevilacqua Wed, 05/20/2009 - 05:43
  • Hall of Fame,
    Founding Member
I don't think you can do anything with mgcp.
With H.323, you can use some script like a I wrote to add a anme.
