Can't archive nexus 5020 configs (LMS 3.1)
tschier
Using LMS 3.1 I can't archive configs from
our Nexus 5020 devices (oid 1.3.6.1.4.1.9.12.3.1.3.719). I have installed
the necessary device package. Following error occures:
*** Device Details for n5-1-060-1 ***
Protocol ==> Unknown / Not Applicable
Selected Protocols with order ==> SSH,TFTP,Telnet
Execution Result:
Unable to get results of job execution for device. Retry the job after increasing the job result wait time using the option:Resource Manager Essentials -> Admin -> Config Mgmt -> Archive Mgmt ->Fetch Settings
I have increased the job result wait time to 3 minutes. Same problem.
Thanks for any hint.
Thomas
5 Replies 5
Marvin Rhoads
Even though the LMS Supported devices table (http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.1/device_support/table/lms31sdt.html) indicates that your device (oid ...3.719) is supported, the readme for the latest Nexus package (Version 1.1, dated 9 May and available here: http://cisco.com/cgi-bin/tablebuild.pl/cw2000-rme) indicates conflicting information, to wit:
"Table 1 Supported Devices in Cisco Nexus Series Package
Cisco Nexus 7000
18-Slot Switch
(N7K-C7018)
1.3.6.1.4.1.9.12.3.
1.3.777
Cisco Nexus 5010
Switch
(N5K-C5010P-BF)
1.3.6.1.4.1.9.12.3.
1.3.798"
I'd go with the readme as more authoritative than the compilation table.
Thanks for the quick answer.
Yes, I've realized this obscurity and i have
deinstalled nexus package version 1.1 and installed the 1.0 version (including Cisco Nexus 5020).
But the same problem occures.
Just some troubleshooting suggestions...
Is your management station able to reach the devices using the appropriate L4 protocol? Check this using the Management Station to Device tool in Common Services.
If so, are the credentials correct? Check this using, for instance, snmpwalk (found under Device Diagnostic Tools > Device Center). You can see all the credential details that CW is using via the dcrcli command line tool.
I'm a little confused. ssh is working from my windows 2003 server to nexus (via putty but if
I check this with Management Station to Device tool the result is
SSHv1 Failed
SSHv2 Failed
TELNET Okay
I've choosen ssh and telnet as transport
settings for fetching configuration.
On the other hand also telnet is not working.
The results of your "Management Station to Device" check lead me to suspect that there is an error with your ability to connect to the Nexus. Are the protocols working with other devices (per the same test)? If so, then the error is specific to either the Nexus config itself or its credentials as stored in the DCR on the server. If not, the the error is most likely in your default credentials or transport setup of the protocol (ssh).
What happens when you try to telnet to the Nexus from LMS (not to fetch configs but just a vty login)? Checking that should narrow down the problem area.
Similarly, we should understand why ssh to the device is not working.
