Phone Designer - unable to connect to the server
May 19th, 2009
  • Bronze, 100 points or more
Just installed it. Read the installation guide cover to cover but I dont get past the initial sign-in.
As always it seems cisco's install guide has omitted some critical bit of information that they take for granted.
help me please
Overall Rating: 0 (1 ratings)
htluo Tue, 05/19/2009 - 05:57
  • Red, 2250 points or more
Check the user ID on CUCM. It's case-sensitive. e.g. on CUCM, the user is JDoe, you can't use jdoe to log in Phone Designer.
If that didn't fix the problem, you need to create a problem report and attach here.
Michael
http://htluo.blogspot.com
Anonymous (not verified) Tue, 05/19/2009 - 06:24
HA!
I got it, apparently you cant use the IP of UCM. I put the hostname in and it worked, which is officially the silliest thing I have seen this week.
