Switching isn't possible in GNS3 or dynamips, because:
Switch IOS is hardware dependent.
Router IOS is software only, so it can be emulated.
The only thing I could recommend would be the 3550 or 3560 series switches to get the full list of features and prep you for CCNP + CCIE.
Manish Prasad Wed, 05/20/2009 - 11:31
Use c3660-ik9o3s-mz.124-6.T IOS and select the NM-16ESW slot though which you can access the 15 ethernet ports and using this you can cover almost 85 percent of the BCMSN practical on it.The same way i used it while preparing for my BCMSN exam.
