Pilot point unregsitered problem
May 19th, 2009
Dear Sir,
i configured new pilot point with some members but i get one of the following status:
1- unknown ; if i don't associate the pilot point with jtapi user.
2- Unregistered ;if i accosiate the pilot point with jtapi user,and in this case i see astrange ip address in the page of CTI route point which refers to third party recording server,but this server has no any configuration on the CCM,so thestrange thing is how CTI route point see this ip and get it!!!
note: after creation the pilot point i resetall of the following :pilot point,cti route point , CTI manager service ,ccm services,and also Attendant console although i don't need it.
i tried to call the pilot point DN from my DN which is registered on the same cluster but i get a busy tone and also i get busy tone when i place the call from pstn .
the cluster composed of one publisher and 2 subscribers each has System version:
your quick prompt is highly appreciated.
Overall Rating: 5 (2 ratings)
Jaime Valencia Tue, 05/19/2009 - 06:46
1 -> Expected
2 -> Also expected, at some point it was registered and then unregistered. You can refer to app log and traces for root cause.
You should have an integration with that JTAPI user to your recording server, CUCM is not a magician that makes things up out of the thin air. Someone must have configured that.
If you only want it to forward calls there is no need to associate it to a user.
if this helps, please rate
valiegenus Tue, 05/19/2009 - 07:34
i have never got Registered status
i deleted every thing and removed pilot point from jtapi,then added pilot point from the beggining without adding it to jtapi,reset cti manager and the status now is unknown,
so what do you think ?
Jaime Valencia Tue, 05/19/2009 - 07:45
OK, let me explain you how status works
If it has NEVER registered = Unknown
If it's registered = Registered
If it was registered and now it's not = Unregistered
There is no unknown to unregistered direct step, even if it was for a split second it should have registered to get the unregistered state.
Unknown is the default state as no integration is using it, configure whatever CF option you need and it will work
