05-19-2009 06:37 AM - edited 03-06-2019 05:48 AM
I have several satellite offices and each office is set up as a different subnet and each has its own Vlan.
There are two offices located in the same hospital. Those offices are connected via 1 T1. The T1 is connected to a switch on subnet 10.1.60.xx on Gi0/2. The other office is connected to that switch but it has its own subnet - 10.1.85.xx and its own vlan. It is connected from Gi0/1 on the first switch via a crossover cable to Gi0/2 on the second switch.
On the port that the T1 is connected to, I have allowed both Vlans.
I have connectivity for both switches with no problems and everything seems fine in that aspect.
Here's my problem: I cannot ping, putty, telnet or Network Assistant into the second switch from my office. However, if I telnet or putty into the first switch I can then telnet from that switch into the second switch.
Any ideas?
05-19-2009 06:45 AM
Steve
It will probably be because the switch using 10.1.85.xx does not have a route back to your source address.
Check if the switch has a default-gateway set on it.
Can you post further details ie.
1) Config of both switches
2) The source IP address from which you are trying telnet/putty
3) It's unclear as to whether there is a router involved here. Are your switches L2 or L3 switches.
If L3 can you also post "sh ip route" from each switch.
If there is a router at the remote office can you post that config as well.
Jon
05-19-2009 06:53 AM
I am trying to putty from 10.1.104.xx.
I am not using a router. These are 2960 Catalyst switches. The connections terminate back to a layer three switch at the main office. I don't have a route on that switch either. That switch is the server for all of the vlans.
05-19-2009 07:02 AM
Can you post config of
1) both switches at remote office
2) "sh ip route" from L3 switch
3) config of L3 switch
Jon
05-19-2009 10:12 AM
1) First switch config:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Monroe_Neuro_SW1
no logging console
enable secret 5
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip domain-name tci.toledoclinic.com
ip name-server 10.1.96.30
ip name-server 10.1.96.31
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 60
switchport mode access
spanning-tree portfast trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport mode trunk
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
mls qos trust cos
macro description cisco-switch
auto qos voip trust
spanning-tree link-type point-to-point
interface GigabitEthernet0/2
description Buckeye T-Marc
switchport trunk allowed vlan 60,85
queue-set 2
mls qos trust cos
auto qos voip trust
interface Vlan1
no ip address
no ip route-cache
interface Vlan60
ip address 10.1.60.2 255.255.255.0
no ip route-cache
ip default-gateway 10.1.60.1
ip http server
snmp-server community
control-plane
line con 0
line vty 0 4
password
login
length 0
line vty 5 15
password
login
length 0
end
05-19-2009 06:46 AM
Does the second switch have a default route pointing towards switch one for the reply packets?
Does the first switch have IP routing enabled?
05-19-2009 07:27 AM
Neither switch has routing enabled.
The default gateway on the second switch is 10.1.85.1 which is the vlan.
05-19-2009 10:20 AM
Switch 2 config:
hostname Monroe_Onco_SW1
enable secret 5
enable password
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
ip subnet-zero
ip domain-name
no file verify auto
switchport access vlan 85
switchport access vlan 71
queue-set 2
mls qos trust cos
auto qos voip trust
description Buckey T-Marc
queue-set 2
mls qos trust cos
auto qos voip trust
interface Vlan1
ip address 10.1.97.19 255.255.224.0
no ip route-cache
interface Vlan71
ip address 10.1.71.211 255.255.255.0
no ip route-cache
interface Vlan85
ip address 10.1.85.2 255.255.255.0
no ip route-cache
ip default-gateway 10.1.85.1
ip http server
control-plane
line con 0
line vty 0 4
login
length 0
line vty 5 15
login
length 0
ntp clock-period 36029174
ntp server 10.1.96.1 key 0 prefer
05-19-2009 10:29 AM
Since the switches aren't doing any routing, it appears that the IP addresses 10.1.60.1 and 10.1.85.1 must be configured on a directly connected router, or routers. Are you able to successfully connect to the switches from the router? Is there a single router handling the routing between the two networks?
05-19-2009 11:32 AM
There are no routers in place. I have a layer 3 Cisco core switch. But there are no routes in it.
I can connect to switch 1 directly. I can then telnet to switch from switch 1.
05-19-2009 02:49 PM
Okay, so the layer 3 core switch has an interface VLAN85 (10.1.85.1) and an interface VLAN60 (10.1.60.1). From the core switch you can access both of your switches on both VLANs. Since the switches are directly connected to the core switch, you won't need any static routes.
I would suggest you verify that the interfaces between the switches are both both up and are both configured as access ports on the appropriate VLAN.
Remember that even though switch1 and switch2 are connected together, in order for there to be communication between the IP addresses on the two different VLANs, the connections to the core switch must be appropriate.
