Can't access Vlan when connected through another switch
May 19th, 2009
I have several satellite offices and each office is set up as a different subnet and each has its own Vlan.
There are two offices located in the same hospital. Those offices are connected via 1 T1. The T1 is connected to a switch on subnet 10.1.60.xx on Gi0/2. The other office is connected to that switch but it has its own subnet - 10.1.85.xx and its own vlan. It is connected from Gi0/1 on the first switch via a crossover cable to Gi0/2 on the second switch.
On the port that the T1 is connected to, I have allowed both Vlans.
I have connectivity for both switches with no problems and everything seems fine in that aspect.
Here's my problem: I cannot ping, putty, telnet or Network Assistant into the second switch from my office. However, if I telnet or putty into the first switch I can then telnet from that switch into the second switch.
Any ideas?
glen.grant Tue, 05/19/2009 - 09:21
Sounds like the second switch is missing the default gateway or a static default route if routing is turned on .
