Error message
  • Unable to create CTools CSS cache directory. Check the permissions on your files directory.
Cisco 1841 with HWIC-1T
May 19th, 2009
Received the Cisco 1841 two weeks ago and configured the Ethernet Interface just fine.
Received the HWIC-1T serial card today. Powered off and unplugged the 1841, attached wrist-strap and inserted the HWIC-1T into an available slot.
Powered up the 1841 but the HWIC-1T is not being recognized. SDM and CLI are not showing a serial interface, just the 2 Ethernet Interfaces.
Is there something else to be done to the 1841 to recognize this serial card?
Show ver:
wat_framerelay#show ver
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 18:17 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
wat_framerelay uptime is 30 minutes
System image file is "flash:c1841-ipbase-mz.124-3i.bin"
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FTX124920D0
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31488K bytes of ATA CompactFlash (Read/Write)
Show interface:
wat_framerelay#show int
FastEthernet0/0 is up, line protocol is up
Hardware is Gt96k FE, address is 0021.a0ee.2d38 (bia 0021.a0ee.2d38)
Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$
Internet address is 172.16.101.253/16
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 0 bits/sec, 1 packets/sec
3521 packets input, 293616 bytes
Received 2764 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
1266 packets output, 187400 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 lost carrier, 0 no carrier
FastEthernet0/1 is administratively down, line protocol is down
Hardware is Gt96k FE, address is 0021.a0ee.2d39 (bia 0021.a0ee.2d39)
Auto-duplex, Auto Speed, 100BaseTX/FX
Last input never, output never, output hang never
0 packets input, 0 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
0 packets output, 0 bytes, 0 underruns
wat_framerelay#
skapter Tue, 05/19/2009 - 07:28
I found 1 error in the log:
Slot 0: Unrecognized cookie format for card!
So..is this an IOS version problem? faulty card?
