howto show current session on ASA/PIX
May 19th, 2009
Hi all,
How can I see the current local host sessions through ASDM (grafically, like show local-host).
Actually, I would like to know which local host is using how much bandwidth.
Norbert
Overall Rating: 3 (1 ratings)
handsy Fri, 05/22/2009 - 02:59
Firstly, you can see bandwidth for local-hosts by using "show local-host detail".
Secondly, I think the only way for you to represent this graphically would be to have a knowledge of SNMP and MRTG-style reporting tools.
On the ASA type "show snmp-server oid" for a list of available OIDs you can monitor.
I am not 100% sure what you are looking for is in that list, although this link:
http://supportwiki.cisco.com/ViewWiki/index.php/SNMP_MIBs_and_Traps_on_the_ASA_-_Additional_Information#Connection_Information
..suggests it may be.
Good luck, and please rate post if it's helped :)
Mark
