Cisco SDM for 2800 series router
Im having an issue with GUI interface appearing. When I try to access my 2800 seriers router using SDM once I enter my username/password the only thing that appears the app script and the interface never appear. Is there something I can do to correct this issue. Thanks for your help in advance.
chris-hart Wed, 05/20/2009 - 21:43
I have this same issue, I'm fairly sure its a Java problem but I'm not exactly what yet.
hvkkartal Thu, 05/21/2009 - 09:43
SDM uses java. It may be incorrect version.
Or can you write error message or snapshot?
chris-hart Mon, 05/25/2009 - 00:58
I had the same issue as this, I don't think SDM is compatible with the lastest Java release. I checked in the SDM 2.5 documentation and it says it needs Java Runtime 6 Update 3 so I downloaded it and removed the latest version of Java to make sure there was no conflict. There is a command line option that you can use to force SDM to run with a particular Java release but I cannot remember it at the moment.
You can download the right version of Java from the Java Archive here:
SDM 2.5 works fine for me now, hope this fixes it for you.
