AS5300, E1 pri, no clock source internal
May 19th, 2009
Hi NetPro
I have problem with a AS5300 and E1 pri interface, the AS5300 have 4 E1 pri contected and working but i need attach a another E1, but when i try to configure the clock source internal, the command it's no avalaible.
regards
paolo bevilacqua Tue, 05/19/2009 - 09:32
  • Hall of Fame,
    Founding Member
Can you post "show controllers e1" and a console log of the clock options presented for the 5th controller.
paolo bevilacqua Tue, 05/19/2009 - 12:46
  • Hall of Fame,
    Founding Member
Can you try configuring clock source line primary for the interface connected to master clock ?
And the console log unsuccesful configuration for a controller you want to use clock internal.
